FME Transformers: 2025.0
2DForcer
Removes z coordinates from features.
Converting 3D geometries to 2D
Optimizing performance when z coordinates are not needed
The 2DForcer receives any geometry type and removes any z coordinates, converting 3D features to 2D.
Features without z coordinates are passed through unchanged.
Point clouds will be reduced to their bounding cube’s footprint.
Raster features, including digital elevation models, are considered 2D and will pass through unchanged.
In this example, we have a CAD file of simple 3D buildings. We are only interested in their footprints, and so want to convert them to 2D.
The features are routed into a 2D Forcer. This transformer has no parameters to configure.
The output features are 2D.
Note that structures had a base elevation of around 5 meters, whereas the 2D output polygons are shown at zero as they have no z coordinates.
Features with any z coordinates removed.
Search for all results about the 2DForcer on the FME Community.
