Microsoft SQL Server (JDBC) Reader/Writer
FME can read and write spatial and attribute data held in Microsoft SQL Server database tables.
FME provides read and write access via Microsoft's JDBC driver, which is bundled with FME.
- Microsoft Azure SQL Database Non-Spatial (JDBC) Reader/Writer: MSSQL_JDBC_NONSPATIAL
- Microsoft Azure SQL Database Spatial (JDBC) Reader/Writer: MSSQL_JDBC_SPATIAL
Product and System Requirements
Format |
FME Platform |
Operating System |
Reader/Writer |
FME Form |
FME Flow |
FME Flow Hosted |
Windows 64-bit |
Linux |
Mac |
Reader |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Writer |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variables allow you to specify memory available to Java Plugins:
