FME Data Types
FME supports the following data types. FME uses these data types when Mapping Attributes from Reader to Writer.
Type |
Description |
Range (if applicable) |
fme_data_type |
binary(width) |
Binary stores fixed-length binary data. Width defines the size, in bytes. |
fme_binary(width) |
binarybuffer |
Binary buffer stores unbounded (of any size) binary data. |
fme_binarybuffer |
buffer |
Buffer stores unbounded (of any length) character strings.
fme_buffer |
char(width) |
Character stores fixed-length string data. Width defines the maximum number of characters that can be stored. No padding is required for strings shorter than this width - they may be of any length up to the defined width. |
fme_char(width) |
date |
Date store dates as character strings with the format YYYYMMDD. |
fme_date |
datetime |
Date/Time stores dates as character strings with the format [Date][Time], as in: YYYYMMDDHHMMSS.FFF The [Time] component may be formatted with or without fractional seconds, and with or without a UTC offset. |
fme_datetime |
int16
Integer, 16-bit stores signed integers in 2 bytes (16 bits) of space. |
-32768 to 32767 |
fme_int16 |
int32 |
Integer, 32-bit stores signed integers in 4 bytes (32 bits) of space. |
-2147483648 to 2147483647 |
fme_int32 |
int64 |
Integer, 64-bit stores signed integers in 8 bytes (64 bits) of space. |
-9,223,372,036,854,775,808 to 9,223,372,036,854,775,807 |
fme_int64 |
int8 |
Integer, 8-bit stores signed integers in 1 byte (8 bits) of space. |
-128 to 127 |
fme_int8 |
json |
JSON stores unbounded strings formatted in JSON (JavaScript Object Notation). |
fme_json |
logical |
Logical stores TRUE/FALSE data, which may be any of:
fme_boolean |
number(width, precision) |
Number stores single and double precision floating point values. Width is the total number of characters allocated to the field, including the decimal point. Precision controls the precision of the data and is the number of digits to the right of the decimal. |
fme_decimal(width,decimal) |
real32 |
Real32 stores floating-point numeric data that occupies 4 bytes (32 bits) in standard IEEE floating-point format. There is no ability to specify the precision and width of the field. |
3.4E +/- 38 (7 digits) |
fme_real32 |
real64 |
Real64 stores floating-point numeric data that occupies 8 bytes (64 bits) in standard IEEE floating-point format. There is no ability to specify the precision and width of the field. |
1.7E +/- 308 (15 digits) |
fme_real64 |
time |
Time store times as character strings with the basic format YYYYMMDDHHMMSS.FFF They may be formatted with or without fractional seconds, and with or without a UTC offset. |
fme_time |
uint16 |
Unsigned integer, 16-bit stores integers greater than or equal to 0 in 2 bytes (16 bits) of space. |
0 to 65535 |
fme_uint16 |
uint32 |
Unsigned integer, 32-bit stores integers greater than or equal to 0 in 4 bytes (32 bits) of space. |
0 to 4294967295 |
fme_uint32 |
uint64 |
Unsigned integer, 64-bit stores integers greater than or equal to 0 in 8 bytes (64 bits) of space. |
0 to 18,446,744,073,709,551,616 |
fme_uint64 |
uint8 |
Unsigned integer, 16-bit stores integers greater than or equal to 0 in 1 byte (8 bits) of space. |
0 to 255 |
fme_uint8 |
varbinary(width) |
Variable-length binary data. Width defines the maximum size, in bytes. |
fme_varbinary(width) |
varchar(width) |
Variable character fields store variable length strings. Width controls the maximum number of characters that can be stored by the field. These are often used to optimize storage. |
fme_varchar(width) |
xml |
XML stores unbounded strings formatted as XML (Extensible Markup Language). |
fme_xml |
