FME Flow: 2025.0
                                                     Logging Out
                                                To end your login session, click the User Settings icon in the upper-right corner of the page, and select Logout.
Note  Depending on your FME Flow configuration, it is possible for users to log in to an FME Flow service through their browser's authentication window instead of through the Web Interface login page.
                                                Users who have logged in this way can log out completely only by clearing their web cache.
There is no session timeout when logged in to FME Flow. Users concerned about leaving their browsers exposed should log out of FME Flow when not in use, or lock their computers manually or through a pre-configured timeout.
