FME Flow: 2025.0
Uploading Data Files Using the Web User Interface
The Data Upload Service is accessed in a different way than access for other services using the Web User Interface.
You can upload data files for Data Download, Data Streaming, and Job Submitter services.
When a published parameter of a workspace represents a file, you can specify the file you want to upload. This action invokes the Data Upload service to upload the file to FME Flow.
- From the Run Workspace page, specify the repository and workspace for which you want to upload data files.
- Specify the service that requires the upload.
- Under Published Parameters, in the applicable file upload field (such as Source File), click the applicable button to select the file to be uploaded. To upload a Resources file, click Browse Resources. To upload a file in another location, such as your local hard drive, click Upload File. Alternatively, if supported by your browser version, you can drag and drop the file onto the field.
