FME Flow: 2025.0
Topic Monitoring
Select System Configuration > Network & Email.
These settings are typically configured only when Installing a Scalable, Fault-Tolerant FME Flow or when using a load balancer. For more information, see Set Up the Load Balancer and Configure with FME Flow
