FME Flow: 2025.0
Dropbox Directory
The Dropbox Directory external action receives messages and uploads files to a folder of a Dropbox account.
The Dropbox Directory external action has two output ports. The success port (✔) can send a message if the upload is successful. The failure port (x) can send a message if the upload fails.
Note  When Retry settings are configured, the failure port renders with a Retry Configured (⟳) icon.
Configuring Your Dropbox Account App
Before creating a Dropbox Directory external action on a Dropbox account, you must configure the account with an app.
Tip  To test that your parameters work as expected, click Validate.
  • Authentication Mode: Specifies the type of OAuth2 access token for the Dropbox account to which you want to upload.
    • Use Authorization Code: Use a Dropbox token generated dynamically. You must authorize with Dropbox to generate an access token, which expires after a four-hour session, and a refresh token that is applied automatically for longer access:
      1. Click Authorize.
      2. On the Authorize Dropbox dialog, provide the following credentials for your Dropbox account app:
        • App Key
        • Authorization Code
        • App Secret
      3. Click Authorize.
    • Use Token: Use a Dropbox access token generated before September 2021 that does not expire.
  • Access Token: If Use Authorization Code is specified above, this field auto-populates after Dropbox authorization is completed. If Use Token is specified above, provide the OAuth2 access token for the Dropbox account you want to watch.
  • Refresh Token: If Use Authorization Code is specified above, this field auto-populates after Dropbox authorization is completed.
  • Access Token Expiry: If Use Authorization Code is specified above, this field auto-populates after Dropbox authorization is completed.
  • Source Path: The source file to upload. If the source file is saved to a Resources directory, click the ellipsis (...) and select the file. If the file is in a different location, enter the file path directly. File paths must use forward slashes (/) or escaped backslashes (\\).
  • Destination Path: The path to the Dropbox folder to upload the file.
Note  Specify file paths using forward slashes (/) or escaped backslashes (\\).
Output Attributes
See Also
Tip  To view the output attributes from upstream components, click Show Upstream Attributes.
Attribute Description
time Event time
source Event type
file.path (Success port only) File path
error.type
(Failure port only) Error type:
  • InvalidMessage: An error occurred while configuring this component, such as missing or malformed values.
  • DeadLetter: An error occured while connecting to an external resource. Examples may include connection issues, invalid credentials, or generic external resource exceptions.
error.message (Failure port only) Error message
dropbox.requestId (Failure port only) Request ID
Retry
  • Retry on failure: If checked, the automation attempts to run the action again if the initial attempt results in a failure to connect to the specified external resource for message delivery. The manner in which these retries are conducted is based on the remaining settings.
  • Use custom retry settings: If checked, the remaining retry settings are configurable. If not checked, they are set to the FME Flow default values.
  • Number of attempts: Maximum number of retries, if the action continues to fail.
  • Wait between attempts: Time to wait between retries. In conjunction with Backoff multiplier (below), the specified value is the wait time for the first retry.
  • Backoff multiplier: Factor by which to increase Wait between attempts on successive retries. For example, a value of 2.0 doubles the wait time for the next retry.
  • Randomization factor: Percentage by which to introduce randomness to Wait between attempts. For example, if Wait between attempts is 100 Seconds, and Randomization factor is 25, the wait time for each retry is randomly selected between 75 and 125 seconds.
  • Maximum wait between attempts: Maximum wait time between retries. In conjunction with Backoff multiplier, the specified value is the upper limit for wait time.
