FME Flow: 2025.0
Log a Message
The Log a Message action logs all message it receives to the Automation log for the workflow.
Tip To view the automation log, click Go to Logs under Log Details. The Automation Log page filters to display only logs that were created explicitly from Log a Message actions.
Note See also Working with Parameters in Automations Workflows.
- Formatted Message: Specify a message to append to the beginning of the log.
