FME Flow: 2025.0
Azure Event Grid Publisher
The Azure Event Grid publisher receives Microsoft Azure events and notifies topics about them.
Note  The FME Flow must be publicly accessible with a valid SSL certificate. For more information, see Configuring for HTTPS.
                                                Protocol Settings
- Webhook Endpoint: The webhook endpoint from which to receive events.
Note  The id segment acts as an access token to verify that the event is coming from Azure Event Grid, and should be kept private.
