FME Flow: 2025.0
                                                     Test the Installation
                                                To test your FME Flow installation, confirm that FME Flow can perform its primary function—running a job.
- On the Run Workspace page, specify:
 - Repository: Samples
 - Workspace: austinApartments.fmw
 - Service: Job Submitter
 - Click Run Workspace.
If you see a success message, your install was a success.
See Also
