FME Flow: 2025.0
Changing the Database Provider for the FME Flow Database
To change the database provider for the FME Flow Database, perform an “in-place” backup and restore procedure:
- Backup Your FME Flow Configuration
- Configure the New Database Server
- Configure the Database Connection
- Restart FME Flow
- Restore Your FME Flow Configuration
- Remove Dependency, Disable, and Stop the Previous Database Service
FME Flow supports PostgreSQL (recommended), SQL Server, or Oracle databases.
Perform a backup of your FME Flow configuration.
Run the necessary database configuration scripts and post-configuration scripts. Follow the steps in Configure the FME Flow Database on a Separate Database Server.
If using an Oracle database server, you must obtain the Oracle Database JDBC driver and place it in the following directory:
- Windows:
- <FME FlowDir>\FMEFlow\Utilities\jdbc
- Linux:
- /opt/fmeflow/Utilities/jdbc
Driver versions recommended: 12.1 (ojdbc7.jar), 12.2 (ojdbc8.jar), 18.3 (ojdbc8.jar), 19.3 (ojdbc8.jar), 19.3, 19.6, 19.7 (ojdbc8.jar).
Driver versions not recommended: All ojdbc10.jar versions.
For more information, see https://www.oracle.com/technetwork/database/application-development/jdbc/downloads/index.html.
- Encrypt the database password you generated in the previous step. In an initial installation of FME Flow, this password is encrypted in installation files by default. However, it is no longer encrypted when the database server is updated. Follow the procedure in Encrypting the FME Flow Database Password.
- Locate the fmeDatabaseConfig.txt configuration file.
- Under the heading ‘FME SERVER SETTINGS START’, locate the section titled 'Database Connection' and update the parameters for the database you want to use for your repository.
- In SQL Server Configuration Manager, ensure the Protocols for SQLExpress setting for TCP/IP traffic is set to Enable. (In SQL Server Express, this setting is disabled by default.)
- Ensure the Windows service SQL Server Browser is enabled and running for SQL Server Express. This service is required for the JDBC driver to locate a dynamic port. Alternatively, use SQL Server Configuration Manager to configure a fixed port, and specify port=<xxxx> in the DB_JDBC_URL parameter setting, where <xxxx> is the value of the specified port. For example, port=1433.
- In SQL Server Management Studio, set Server authentication to SQL Server and Windows Authentication Mode. This configuration is required because FME Flow uses the DB_USERNAME property to authenticate.
DB_TYPE - Identifies the database server: postgresql, sqlserver, oracle.
DB_DRIVER - The JDBC driver name used for connecting to the database.
DB_JDBC_URL - The JDBC URL used for connecting to the database.
DB_USERNAME - The database user name.
DB_PASSWORD - The database user password.
DB_CONNECT_EXPIRY - The database connection expiry time, in seconds.
DB_SQLSTMTS_PATH - The path to the SQL statement resource bundle.
DB_TYPE=postgresql
DB_DRIVER=org.postgresql.Driver
DB_JDBC_URL=jdbc:postgresql://localhost:5432/fmeflow
DB_USERNAME=fmeflow
DB_PASSWORD=fmeflow
DB_CONNECT_EXPIRY=60
DB_SQLSTMTS_PATH=C:/Apps/FMEFlow/Server/database
To use a local installation of SQL Server Express
Prerequisites:
DB_TYPE=sqlserver
DB_DRIVER=com.microsoft.sqlserver.jdbc.SQLServerDriver
DB_JDBC_URL=jdbc:sqlserver://localhost;instanceName=SQLEXPRESS;databaseName=fmeserver;encrypt=true;trustServerCertificate=true
DB_USERNAME=fmeserver
DB_PASSWORD=$FMEserver
DB_SQLSTMTS_PATH=C:/Apps/FMEServer/Server/database
Note To resolve encryption issues due to invalid certificates, specify encrypt=false in place of encrypt=true;trustServerCertificate=true.
To use a named instance of a SQL Server
Specify the instanceName property with the DB_JDBC_URL parameter:
DB_TYPE=sqlserver
DB_JDBC_URL=jdbc:sqlserver://<ServerName>;databaseName=<database>;instanceName=<InstanceName>
DB_USERNAME=fmeflow
DB_PASSWORD=$FMEflow
To use a domain service account instead of a named database user or fmeflow (the default database username)
Specify the integratedSecurity property with the DB_JDBC_URL parameter. FME Flow uses the Log on as credentials of the FME Flow Core and FME Flow Application Server services to connect to the SQL Server database. Do not set the DB_USERNAME or DB_PASSWORD parameter values.
DB_TYPE=sqlserver
DB_JDBC_URL=jdbc:sqlserver://<ServerName>;databaseName=<database>;integratedSecurity=true
DB_USERNAME=
DB_PASSWORD=
To specify the database connection port
Specify the port after <ServerName> in the DB_JDBC_URL parameter. For example:
DB_JDBC_URL=jdbc:sqlserver://<ServerName>;port=1755;
To specify an Always On availability group
If using an Always On availability group, include the MultisubnetFailover property with the DB_JDBC_URL parameter:
DB_JDBC_URL=jdbc:sqlserver://<ServerName>;databaseName=<database>;MultisubnetFailover=true
To allow failover in a multi-node Azure HA environment
If you are connecting to a high environment (HA) environment on Azure, include connectRetryCount=0 with the DB_JDBC_URL parameter. This property-value pair ensures a new node is tried if the first fails.
To specify an on-premise database with a System ID (SID)
Use the following syntax for the DB_JDBC_URL parameter:
DB_JDBC_URL=jdbc:oracle:thin:@<host>:<port>:<sid>
For example:
DB_TYPE=oracle
DB_DRIVER=oracle.jdbc.driver.OracleDriver
DB_JDBC_URL=jdbc:oracle:thin:@localhost:1521:orcl
DB_USERNAME=fmeflow
DB_PASSWORD=fmeflow
To specify an on-premise database with a service name
DB_JDBC_URL=jdbc:oracle:thin:@<host>:<port>/<servicename>
For example:
DB_JDBC_URL=jdbc:oracle:thin:@hostname.mydomain.com:1521/mydatabase1
To specify an Oracle Cloud database
DB_JDBC_URL=jdbc:oracle:thin:@<ip>:<port>/<servicename>
For example:
DB_JDBC_URL=jdbc:oracle:thin:@129.44.44.2:1521/orcl_iad2fd.mycorpz1.mycorp.myvcn.com
Restart FME Flow
Restart all of the FME Flow System Services.
Perform a restore of your FME Flow configuration.
If the database service from which you migrated is the PostgreSQL database that was included in a default installation of FME Flow (such as an express install), you must remove the dependency of the FME Flow Core on that database, and then disable and stop it. For more information, see Removing the FME Flow Core Dependency on the FME Flow Database.
