FME Flow: 2025.0
Before Installation
Before you install FME Flow for fault tolerance, ensure the following components are in place on your network:
- Separate machines on which to install the number of FME Flows that you have allocated for your fault tolerant architecture.
- A load balancer to route traffic between each FME Flow instance you install.
- Fault-tolerant database server on a separate machine.
- Fault-tolerant file system on a separate machine.
Next Steps
Proceed to Obtain the Installer.
