FME Transformers: 2024.2
ArcPropertySetter
Modifies or creates arc geometry according to new coordinates, angles, radii, or rotation values.
Modifying arc geometry
Converting points to arcs
The ArcPropertySetter receives features with arc or point geometry. Arcs are modified if any values provided in parameters differ from the input geometry. Points are converted to arcs if at least Primary Radius, Start Angle, and Sweep Angle values are provided. The point’s coordinates are used as the arc’s center.
The parameters may modify or create an ellipse as a closed Arc By Center Point or Arc by 3 Points by the following:
Center X, Y, and Z coordinates
Start and End X, Y, and Z coordinates
Primary and Secondary Radius in ground units
Rotation in degrees
Start Angle and Sweep Angle in degrees
Values may be entered or provided through attribute values, expressions, or user parameters.
Features without valid arc or point geometry will be rejected, as will points that do not have the required parameter values to create an arc.
For more information on arc geometry and types, see Arc.
In this example, we have a set of arc features and wish to close them into ellipses.
The features are routed into an ArcPropertySetter.
In the parameters dialog, Sweep Angle is set to 360.
The output features are modified accordingly.
To extract arc properties to use in expressions, use an ArcPropertyExtractor before the ArcPropertySetter.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
Transformer |
Use this to... |
Geometry Out |
Z Coordinates |
Create one or more new features with arc geometry (when Geometry Object is an arc type). |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge Ellipse (Arc by center point) |
Supported |
Replace any existing feature’s geometry with a 2D arc. |
Arc by center point |
Replace any existing feature’s geometry with a 3D arc. |
Yes, at center point |
Replace an existing feature’s geometry with a 2D ellipse or circle (closed arc). |
Modify an existing arc or converts a point to an arc. |
Arc by center point Arc by center point with ends Arc by 3 points |
Supported, at center and/or ends |
Modify an existing ellipse (closed arc) or convert a point to an ellipse. |
Supported, at center point |
Extract the property values that describe an arc’s geometry and store them as attributes. |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge |
Supported |
Extract the property values that describe an ellipse’s geometry and store them as attributes. |
Supported |
Convert arcs and ellipses to lines or polygons by interpolating points along the arc. |
Path Line Area |
Supported |
Replace geometry with an arc described by the first, middle, and last vertices of the input feature. |
Arc by 3 points |
Supported |
Replace lines or polygons with an optimal combination of line and arc segments, creating smooth curving lines. |
Path Area Arc by bulge Line |
Supported |
Reduce point density on lines or polygons, fitting arcs where possible (When using Algorithm > Douglas With Arc Fitting (Generalize) ). |
Path Area Arc by 3 points Line |
Supported |
Either replace an existing feature’s geometry with circle that contains all of its vertices or extract the circle property values into attributes. |
Features with arc or point geometry.
Features with modified or new arc geometry as specified in parameters.
Features without valid arc or point geometry are output via this port, as well as points that do not have the required parameter values to create an arc.
Features that receive non-numeric values for any numeric parameters are output via this port.
INVALID_PARAMETER_PRIMARY_RADIUS
INVALID_PARAMETER_SECONDARY_RADIUS
INVALID_PARAMETER_ROTATION
INVALID_PARAMETER_START_ANGLE
INVALID_PARAMETER_SWEEP_ANGLE
INVALID_PARAMETER_START_POINT
INVALID_PARAMETER_END_POINT
INVALID_PARAMETER_CENTER_POINT
Primary Radius |
Specify the new primary radius of the arc in ground units. Note that the primary radius need not be larger than the secondary, however, the rotation angle is always measured from the x axis to the primary axis. For a circular arc, set both the primary and secondary radius to the same value. |
Secondary Radius |
Specify the new secondary radius of the arc in ground units. |
Rotation |
Specify the new rotation in degrees of the primary axis from horizontal (if any). |
Start Angle |
Specify the new starting angle of the arc, in degrees counterclockwise from the primary axis (horizontal plus or minus rotation). |
Sweep Angle |
Specify the new sweep angle in degrees, which controls the duration of the arc. Positive sweep angles, run counterclockwise beginning at the start angle and ending at the sum of the start and sweep angles. Negative sweep angles run clockwise. |
Start X |
Specify the new x coordinate of the arc’s start point. |
Start Y |
Specify the new y coordinate of the arc’s start point. |
Start Z |
Specify the new z coordinate of the arc’s start point. |
End X |
Specify the new x coordinate of the arc’s end point. |
End Y |
Specify the new y coordinate of the arc’s end point. |
End Z |
Specify the new z coordinate of the arc’s end point. |
Center X |
Specify the new x coordinate of the arc’s center point. |
Center Y |
Specify the new y coordinate of the arc’s center point. |
Center Z |
Specify the new z coordinate of the arc’s center point. |
Search for all results about the ArcPropertySetter on the FME Community.
