FME Transformers: 2024.2
Categories
Coordinates
Related Transformers
3DAffiner
3DRotator
AffineWarper
Offsetter
PointCloudTransformationApplier
RasterRotationApplier
Rotator
Scaler
SecondOrderConformer
Affiner
Performs an affine transformation (such as offset, rotate, or scale) on the coordinates of the feature.
Jump to Configuration
  • Moving, scaling, and rotating 2D geometry.
The Affiner receives features with any geometry type and moves their x and y coordinates according to a specified affine transformation.
An affine transformation is a mathematical method of modifying geometry that:
  • Preserves lines/collinearity: all points on a straight line are still on a straight line after transformation.
  • Preserves parallelism: lines that are initially parallel are still parallel after transformation.
  • May not preserve angles, lengths, or areas, depending on the type of transformation performed.
Scaling, mirroring, rotating, shearing, and translating (relocating or offsetting) are all affine transformations. They can be performed singly or in combination.
The Affiner performs 2D transformations, using this formula:
x' = Ax + By + C
y' = Dx + Ey + F
Where (x,y) are the input coordinates and (x',y') are the transformed output coordinates.
Description
Formula/Coefficients
Example*
Translate
Move the geometry a fixed distance.
x' = 1x + 0y + C
y' = 0x + 1y + F
Simplified:
x' = x + C
y' = y + F
C = horizontal (x) offset
F = vertical (y) offset
x' = 1x + 0y + 5
y' = 0x + 1y + 5
Scale
Shrink or enlarge the geometry.
x' = Ax + 0y + 0
y' = 0x + Ey + 0
Simplified:
x' = Ax
y' = Ey
A = horizontal (x) scale factor
E = vertical (y) scale factor
x' = 1.5x + 0y + 0
y' = 0x + 1.5y + 0
Rotate
Rotate the geometry around the origin.
x' = cos(ϴ)x + −sin(ϴ)y + 0
y' = sin(ϴ)x + cos(ϴ)y + 0
Simplified:
x' = cos(ϴ)x − sin(ϴ)y
ϴ = Angle in degrees
A = cos(ϴ)
B = −sin(ϴ) (Note negative value)
D = sin(ϴ)
E = cos(ϴ)
Rotate 30 degrees:
x' = 0.866025x + -0.5y + 0
y' = 0.5x + 0.866025y + 0
Shear
Offset geometry in proportion to its x and y coordinates.
x' = 1x + By + 0
y' = Dx + 1y + 0
Simplified:
x' = x + By
y' = y + Dx
x' = 1x + 1.25y + 0
y' = 0x + 1y + 0
* Note these examples use geometry with an origin of 0,0 at the lower left corner of the polygon.
Geographic Features and Affine Transformations
The origin (0,0) of geographic features is generally at a distance from the geometry itself, and so affine transformations can produce large location shifts, in particular when scaling or rotating.
  • To perform affine transformations in place on geographic features, consider temporary reprojection (Reprojector) to a local coordinate system or using the CommonLocalReprojector.
  • The Scaler performs 2D and 3D scaling affine transformations, with additional options for specific geometry types and origin handling.
  • The Offsetter performs 2D and 3D translation affine transformations, with additional coordinate space options (polar and spherical coordinates, in addition to cartesian).
  • The Rotator and 3DRotator perform rotation affine transformations, with a simplified interface for rotation value, origin (2D) and axis choice (3D).
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the Affiner on the FME Community.
