Snowflake Non-Spatial: Add Database Connection
To define a new connection from the Connection parameter in a Snowflake format:
- Select Add Database Connection. See database-specific parameters below, as well as the section Adding a Database Connection in a Workspace in Using Database Connections The new connection can be made visible only to the current user, or can be shared among multiple users.
Database Connection
Snowflake
Name
Enter a name for the new connection.
Connection Parameters
Account Name
The full name of your Snowflake account.
For example, if you access your Snowflake System in a web browser using a URL like this:
https://mycompanyinc.snowflakecomputing.com/
then your full account name is mycompanyinc.
Warehouse
The virtual warehouse to use once connected. The specified warehouse should be an existing warehouse. This parameter is case-sensitive.
Database
Specifies the default database to use once connected. The specified database should be an existing database. This parameter is case-sensitive.
Schema
Specifies the default schema to use once connected. The specified schema should be an existing schema. This parameter is case-sensitive.
Role
Specifies the default access control role to use in the session. The specified role should be an existing role that is already assigned to the specified user.
Authentication
The method used for authentication.
- Basic uses Snowflake username and password.
- OAuth Connection connects using Microsoft Azure Active Directory OAuth 2.0 web service, or Client Credentials web service.
- Browser-based SSO uses Single Sign-On (with a username and password) to connect via an external web browser. This method supports MFA (Multi-Factor Authentication).
Username and Password
The username and password to connect to the specified account, warehouse, database, and schema. These parameters are enabled when the Basic authentication method is selected.
OAuth Connection
The web connection to use to obtain a valid OAuth token. This option is enabled when the OAuth Connection authentication method is selected.
A Microsoft Azure Active Directory (Template) web service has been provided in your FME installation. To configure a new Microsoft Azure AD web service, create a new web service from this template, replacing [TENANT_ID] and [OAUTH_SCOPE] with the appropriate values.
For more information, see Configure Microsoft Azure AD for External OAuth on the Snowflake documentation website.
For Client Credentials authentication, please create a new web connection using the provided Microsoft Azure Active Directory (Client Credentials) web service.
Advanced – Specify JDBC Connection
When enabled, this parameter will allow the JDBC connection string and properties to be specified directly, in order to connect to the database.
Option |
Description |
Connection String |
The connection string for the database to which you are connecting. |
Mask Connection Details |
Connection details may contain sensitive information, such as passwords. A masked connection string appears as: jdbc:<subprotocol>:************ While masked connection properties appear as: {<property_name1>=************, Warning Connection strings for connections whose parameters are embedded in the workspace are not masked, regardless of this setting.
Connection Property and Value |
JDBC connections can be configured with driver-specific arbitrary name/value pairs. The name/value pairs can often be specified in either the Connection String or a Properties object (sometimes only in one way or the other). Name/value pairs entered here will be set in the order specified, then passed on in a Properties object. They do not require manual encoding of characters that are not safe in Connection Strings. |
