OGC API – Features Reader Parameters
Note   The source dataset must be a URL to the server’s JSON Landing page or the server’s JSON Collections resource.
Use Network Authentication
Note  To access datasets using a proxy server, use the Network tools in FME Options. From the FME Workbench menu, select Tools > FME Options > Network. For more information, see Network Proxy in FME Workbench Help.
Connection Properties
Constraints
Collections
Collections correspond to Feature Types in FME. This parameter lets you browse and select Collections for which to generate Feature Types.
The collections are gathered from server’s Collections resource.
Additional Parameters
Add ogcapi_source_url Attribute
Adds the ogcapi_source_url attribute to every feature read. The value of the attribute is the URL that was used to retrieve a collection from the server.
