Microsoft SQL Server Spatial User Attributes
Readers: For information on the parameters in this dialog that are common to all readers, see:
Writers: For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Type |
Description |
bigint |
Represents 64-bit signed integers. |
binary |
Represents fixed-length binary data up to a length of 8000 bytes. |
bit |
Represents an integer with a value of 1 or 0. |
char |
Represents fixed length character data up to a length of 8000 bytes. Note The number of characters that can be stored depends on the code page of the server.
date |
Represents date data from January 1, 0001 to December 31, 9999. FME supports the years 1000 to 9999. For writers, as long as the input value is a valid date/time – and it contains a date component – the date component will be written. |
datetime |
Represents date and time data from January 1, 1753 to December 31, 9999 with an accuracy that is rounded to the nearest 0, 3, or 7 milliseconds. When Bulk Insert = Yes, writers support writing fractional seconds; otherwise, they do not. For writers, as long as the input value is a valid date/time – and it contains a date component – a datetime value will be written, with midnight appended if the time component is missing. If input date/time has greater precision than supported by the database, the writer rounds the input fractional seconds to within the supported precision. |
datetime2(width)
Represents date and time data from January 1, 0001 to December 31, 9999 with an accuracy of 100 nanoseconds (7 fractional digits). FME supports the years 1000 to 9999. For writers, as long as the input value is a valid date/time – and it contains a date component – a datetime value will be written, with midnight appended if the time component is missing. If input date/time has greater precision than supported by the database, the writer rounds the input fractional seconds to within the supported precision. See Standard FME Date/Time Format. (width) Specifies the number of digits for the fractional part of the seconds. The width can be an integer from 0 to 7. |
datetimeoffset |
Defines a date that is combined with a time of a day based on a 24-hour clock like datetime2, and adds time zone awareness based on UTC (Universal Time Coordinate or Greenwich Mean Time). The maximum width for this attribute is 7. |
float |
Represents 64-bit floating precision numbers. |
identity |
Represents an auto-incrementing integer field. Note If you try to write a value to it; the value will be ignored and the database will simply take the largest integer in the column, increment it and insert that number into the field.
image |
Represents variable-length binary data up to a length of 2^31-1 bytes. |
integer |
Represents 32-bit signed integers. |
money |
Represents monetary data values from -2^63 to 2^63-1. Attribute values are real numbers such as 55.2354. |
nchar |
Represents fixed-length character data up to a length of 4000 Unicode UCS-2 characters. |
ntext |
Represents variable-length character data up to a length of 2^30-1 Unicode UCS-2 characters. |
numeric |
Represents fixed precision and scale numeric data from -10^38+1 to 10^38+1. |
nvarchar |
Represents variable-length character data up to a length of 4000 Unicode UCS-2 characters. |
nvarchar_max |
Represents variable-length character data up to a length of 536,870,912 Unicode UCS-2 characters. |
real |
Represents 32-bit floating precision numbers. |
smalldatetime |
Represents date and time data from January 1, 1900 to June 6, 2079 with an accuracy of one minute. For writers, as long as the input value is a valid date/time – and it contains a date component – a datetime value will be written, with midnight appended if the time component is missing. If input date/time has greater precision than supported by the database, the writer rounds the input fractional seconds to within the supported precision. |
smallint |
Represents 16-bit signed integers. |
smallmoney |
Represents monetary data values from -214748.3648 to 214748.3647. Attribute values are real numbers such as 55.2354. |
text |
Represents variable-length character data up to a length of 2^31-1 bytes. Note The number of characters that can be stored depends on the code page of the server.
time(width) |
Represents time data with an accuracy of 100 nanoseconds (7 fractional digits). For writers, as long as the input value is a valid date/time, the time component will be written. If the time component is missing, midnight (00:00:00) will be written. If input date/time has greater precision than supported by the database, the writer rounds the input fractional seconds to within the supported precision. See Standard FME Date/Time Format. (width) Specifies the number of digits for the fractional part of the seconds. This can be an integer from 0 to 7. |
timestamp |
Stores a unique number which is updated every time a row gets created or modified. The timestamp value is based upon an internal clock and does not correspond to real time. Each table may have only one timestamp variable. |
tinyint |
Represents numbers between 0 and 255. |
uniqueidentifier |
Represents GUIDs. As such, it must be set up like a valid GUID. Example: {B85E62C3-DC56-40C0-852A-49F759AC68FB} Note The {} must be present for the GUID to be written successfully.
varbinary |
Represents variable-length binary data up to a length of 8000 bytes. |
varbinary_max |
Represents variable-length binary data up to a length of 2 GB. |
varchar |
Represents variable-length character data up to a length of 8000 bytes. Note The number of characters that can be stored depends on the code page of the server.
varchar_max |
Represents variable-width binary string to a maximum size of 2 GB. |
xml |
Represents XML documents and fragments. |
Index |
The type of index to create for the column. If the table does not previously exist, then upon table creation, a database index of the specified type is created. The database index contains only one column. Note A given table can contain, at most, one clustered index.
The valid values for the column type are listed below:
