Microsoft Access (JDBC) User Attributes
Readers: For information on the parameters in this dialog that are common to all readers, see:
Writers: For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name | The name of the field to be written. |
Type |
This format supports the following field types. autonumber Used to generate an automatically incremented numeric counter. Only one autonumber field is allowed in each table. bigint This type is used to represent 64-bit signed integers. Note Support for this type is available only to Office 365 subscribers.
byte Represents 8-bit unsigned integers. currency Represents monetary data values up to 15 digits of whole dollars and 4 decimal places. datetime Represents date and time data January 1, 0100 to December 31, 9999 with an accuracy of 3.33 milliseconds. Note: FME accurately represents data only after the date October 15, 1582. See Standard FME Date/Time Format. decimal Represents fixed precision and scale numeric data from -10^28-1 through 10^28-1. double Represents 64-bit floating precision numbers. hyperlink Represents a hyperlink. Values must be provided in the Microsoft Access anchor#link# format. integer Represents 16-bit signed integers. long Represents 32-bit signed integers. memo Represents character data up to a length of 65,536 characters. oleobject Represents binary large objects. The data must be specially formatted to be read correctly in Microsoft Access. replicationid Represents GUIDs. As such, it must be set up like a valid GUID. For example: {B85E62C3-DC56-40C0-852A-49F759AC68FB} single Represents 32-bit floating precision numbers. text Represents character data up to a length of 255 characters. yesno Represents a logical field with a value of True or False. Nulls are automatically changed to False in yesno fields. |
Index |
The types of indexes and constraints to create for the column, if the table is created. Indexes and constraints are only created if the table is created. Each index and constraint contains only one column. The valid values for the column type are listed below: PrimaryKey: This type specifies that the column is a primary key for the table. Only one primary key is allowed per table. Unique: This type specifies that the column has a UNIQUE constraint. NotNull: A non-nullable constraint. |
