FME Form: 2024.2
Register Services
This page allows you to register your workspace, custom transformer, or custom format with one or more of the FME Flow Web Services.
If the web service contains configurable parameters, click the Edit... button next to the service you want to configure. For more information, see Edit Service Properties below.
Note  For more information, see FME Flow Web Services in the FME Flow documentation.
Select one or more web services and click Publish to publish the workspace to FME Flow.
Note  If you uploaded any connections in the previous step (Upload Connections), click the link at the bottom of the translation log to configure web services and authorize connections in FME Flow. For more information, see Upload Connections.
The properties that are available to configure in this dialog depend on which FME Flow service you are editing.
