FME Flow: 2024.2
Configuring System Cleanup Settings
Select System Configuration > System Cleanup > Configuration.
On the Configuration tab of the System Cleanup page, you can adjust cleanup settings in the following ways:
- Changing the frequency of system cleanup tasks.
- Configuring Default Cleanup and Aggressive Cleanup events.
Changing the Frequency of System Cleanup Tasks
By default, all maintenance tasks on the Tasks and Completed Jobs tabs run once per day. To change this frequency:
- Under Normal Conditions, update the Task Interval fields.
- Click Save Settings.
Configuring Default Cleanup and Aggressive Cleanup Events
When the system's free disk space reaches specified minimum levels, FME Flow executes the following types of cleanup events:
- Default Cleanup: All enabled cleanup tasks on the Tasks and Completed Jobs tabs execute, regardless of the Task Interval setting.
- Aggressive Cleanup: All enabled cleanup tasks on the Tasks and Completed Jobs tabs execute, disregarding the Remove Files/Completed Jobs Older Than setting. In other words, all files specified by each cleanup task are removed, regardless of their age.
To configure when FME Flow undertakes a Default Cleanup or Aggressive Cleanup event:
- Configure how often you want FME Flow to check free disk space for triggering a cleanup. By default, FME Flow checks every 5 minutes. To change this frequency, under Low Disk Conditions, update the Watch Interval fields. Alternatively, to disable checking, specify 0. Setting to 0 effectively turns off Default Cleanup and Aggressive Cleanup events.
- Under Default Cleanup and/or Aggressive Cleanup, configure the minimum disk space requirements for allowing cleanup events, as follows:
- Disk (%): The minimum free disk space size, in percentage.
- And/Or: If AND, the detected minimum Disk (%) AND Disk Space (GB) must both be less than the specified values to allow a cleanup event. If OR, either the detected minimum Disk (%) OR Disk Space (GB) must be less than the specified values to allow a cleanup event.
- Disk Space (GB): The minimum free disk space size, in gigabytes.
- Topic to Notify: The Notification Service topic to receive messages about cleanup events. Although this field is optional, there is no way to receive messages when cleanup events occur, unless you specify a topic, and then configure an Automations workflow to receive the message. Most likely, you will configure a Email external action; however, protocols for other Automations External Actions are available.
Select from an existing topic, or click
to create and use a new topic.
For the JSON template of the notification, see Notification Schema (below).
Notification Schema
If Topic to Notify is specified under "Default Cleanup" or "Aggressive Cleanup", a notification is delivered to the specified topic containing the following JSON-formatted message:
"msg": "<default_or_aggressive_level_message>",
"detectedFreeGB": "<free_disk_space_in_gigabytes_detected>",
"detectedFreePCT": <free_disk_space_percentage_detected>",
"minFreeGB": <minimum_free_disk_space_in_gigabyte_default_or_aggressive_criteria>",
"minFreePCT": <minimum_free_disk_space_percentage_default_or_aggressive_criteria>",
"drive": <Source_drive_path_checked>",
