FME Flow: 2024.2
FME Flow Topic
The FME Flow Topic trigger sends messages generated from FME Flow Notification Service Topics.
The FME Flow Topic trigger has two output ports. The success port (✔) can send a message if the trigger fails. The failure port (x) can send a message if the trigger succeeds.
Note  Use the Topic trigger only to initiate a workflow, or a portion of a workflow. It is otherwise not necessary to explicitly define topics for a workflow to run.
  • Topics: Select the topic(s) you want to send messages.
Output Attributes
See Also
Accessing Topic Messages
FME Flow topics store incoming messages as JSON-formatted strings. If a topic message was generated as plain text, it is stored under the attribute subscriber_content. If a topic message was generated as JSON, it is stored under the applicable JSON attribute.
Other Attributes
Attribute Description
time
Event time
source Event type
error.type
(Failure port only) Error type:
  • InvalidMessage: An error occurred while configuring this component, such as missing or malformed values.
  • DeadLetter: An error occured while connecting to an external resource. Examples may include connection issues, invalid credentials, or generic external resource exceptions.
error.message (Failure port only) Error message
