FME Flow: 2024.2
Filter Messages
The Filter Messages action tests incoming messages for the presence of a string in the value of a specified output attribute. Messages that pass this test are output through the success port (✔). Messages that fail this test are output through the failure port (x).
  • Key: Specify an output attribute on which to filter.
  • Contains: Specify a string (case-sensitive) in Key on which to test presence.
