MapBox MBTiles Vector Tiles (MVT) Geometry Support
See Also
Geometry |
Supported? |
Notes |
Converted to Line on write. |
No
Converted to Surface on write. |
No
No
Converted to MultiSolid on write. |
No
Converted to MultiSurface on write. |
Coordinate Precision |
Full |
64-bit floating point coordinates. |
No
Yes |
Converted to Polygon on write. |
No
No
Multipatch |
Georeferencing |
Native |
Web Mercator tile system. |
Yes |
If containing only points, lines, or polygons. |
Yes |
No
Yes |
Multipolygons only. |
Yes |
Multilines only. |
Yes |
No
No
Multipatch |
Yes |
Stroked to lines. |
Stroked to polygon from bounding box. |
Yes |
Yes |
No
Surface Sidedness |
Text location geometry is converted to a point. |
Triangle Fan |
No
No
Z values |
