IBM Informix Non-Spatial (JDBC) Writer Parameters
About Database Connections
Database formats include a Database Connection parameter that defines and stores authentication information. For general information about sharing database connections, please see Using Database Connections. Using Database Connections.
Note that Database Connection parameters differ slightly, depending on context and/or database format.
Connection
From the Connection parameter in a database format, you can do one of the following:
  • Select an existing, previously defined connection. See the section Reusing a Database Connection in Using Database Connections
  • Select Add Database Connection to define a new connection. See database-specific parameters below, as well as the section Adding a Database Connection in a Workspace in Using Database Connections. The new connection can be made visible only to the current user, or can be shared among multiple users.
Database Connection
Select an existing IBM Informix database connection, or Add Database Connection...
Add IBM Informix Database Connection
To define a new connection from the Connection parameter in an IBM Informix format, see the topic IBM Informix Non-Spatial (JDBC): Add Database Connection
Advanced
Query Timeout (Seconds)
This parameter defines the time, in seconds, after which a query will be terminated if it has not yet returned a result.
If set to 0, there is no timeout. The default is 30.
Note  If this value is not set high enough, then the query will return the error Provider Error – Timeout Expired.
