Industry Foundation Classes (IFC) Feature Representation
This section describes the features that are output from the IFC reader.
Quick Links
Coordinate System
Coordinate System to Read
Attributes
Common Attributes
Common Attributes for Geometric Elements
Attributes for Texture Information
Special Feature Types
Non Geometric Feature Types
Project
OwnerHistory
PresentationLayerAssignment
Group
Esri *.prj and *.wld/wld3 Files
FME will search the folder of the dataset for a file with the same name as your dataset but with a projection file (.prj) extension. If it cannot find a file with that name, it will then look for the file esri_cad.prj within the dataset folder. If either of those files exists, FME will use the coordinate system information contained within to geolocate the IFC file.
If a .prj file is found, FME will also search the folder of the dataset for a file with the same name as your dataset, but with a world file extension (.wld or .wld3). If it cannot find a file with that name, it will then look for the file esri_cad.wld/esri_cad.wld3 within the dataset folder. If either of those files exists, FME will use the information in the file to translate the coordinates of the features in the dataset to their new geospatial coordinates.
If no .wld/.wld3 file is found, the translation will continue using the georeferencing information found in the .prj file, while reading coordinates in the coordinate system defined by the IFC file’s Survey Point. The reader will also use the file’s defined Project Units.
If the files cannot be found, then the translation will continue, using the coordinate information found in the dataset, without performing any additional transformation.
For more information on creating .prj and .wld/.wld3 files in ArcGIS Pro, please refer to the ArcGIS help page: Geospatial position of CAD and BIM data.
Native IFC Georeferenced Coordinate System
If FME does not find an Esri .prj file,it will instead look for georeferenced coordinate system information on the IfcMapConversion and IfcProjectedCRS elements in the IFC dataset. In order for the dataset to be properly georeferenced, the IFC file needs to reference a valid coordinate system with a correctly specified IfcMapConversion.
If FME finds georeferencing data in the IFC dataset, it will set the coordinate system name to the coordinate system it finds in the dataset and will geolocate features using the transformation specified by the IfcMapConversion.
Attributes
Common Attributes
Attribute/Trait Name
Contents
ifc_name
The name of the instance the feature represents.
ifc_global_id
The global ID of the instance the feature represents.
ifc_parent_id
The hierarchical parent global ID of the instance the feature represents.
ifc_element_type
The IFC element type IfcElementType.
ifc_description
The description of the instance the feature represents.
ifc_element_id
The element ID (AKA STEP instance name) of the instance the feature represents.
FME will read the following attributes on features representing geometric elements:
Contents
ifc_context_identifier
The context identifier for the instance this feature represents.
ifc_context_type
The context type for the instance this feature represents.
ifc_representation_identifier
The representation identifier for the instance this feature represents.
ifc_representation_type
The representation type for the instance this feature represents.
FME will read the following attributes if the geometry contains a texture:
Texture Type
Contents
ifc_texture_type
The type of texture on the geometry. Types include IfcImageTexture, IfcBlobTexture, and IfcPixelTexture.
ifc_texture_urlreference
IfcImageTexture
The filename or url of the image.
ifc_texture_rasterformat
IfcBlobTexture
Indicates the format (such as “PNG”) of the embedded raster.
ifc_texture_rastercode
IfcBlobTexture
This attribute will contain the binary blob representing the raster.
ifc_texture_width
IfcPixelTexture
This attribute defines the width of the raster.
ifc_texture_height
IfcPixelTexture
This attribute defines the height of the raster.
ifc_texture_colourcomponents
IfcPixelTexture
This attribute defines the number of components within each pixel.
ifc_texture_pixel
IfcPixelTexture
This attribute defines the binary blob of the embedded raster.
The following feature types are always read without geometry, but have useful attributes:
Project
The Project feature type reads the single IfcProject element in the dataset. It has the following unique attributes:
Contents
ifc_longname
The long name of the project.
ifc_phase
The phase of the project.
ifc_schema
The schema of the project.
Additionally, some Ifc project units of type IFCSIUNIT are read and stored as attributes on this feature. These are:
Unit
ifc_project_currency
ifc_project_area_unit
ifc_project_length_unit
ifc_project_mass_unit
ifc_project_time_unit
ifc_project_volume_unit
OwnerHistory
The OwnerHistory feature type reads the single IfcOwnerHistory element in the dataset. It has the following unique attributes:
Contents
ifc_state
The state of the dataset.
ifc_last_modified_date
The last modified date of the project.
ifc_creation_date
The creation date of the project.
ifc_change_action
The value of the IfcChangeActionEnum for the project.
The PresentationLayerAssignment feature type reads one feature for each PresentationLayerAssignment element in the dataset. It has the following unique attributes:
Contents
ifc_assigned_items{}
Each entry in this list attribute holds the ID of an element assigned to the IfcPresentationLayer represented by this feature.
Group
The Group feature type reads one feature for each group in the dataset. It has the following unique attributes:
Contents
ifc_group_member{}
A list attribute that contains one entry with the ID of each member in the group.
