Esri Geodatabase Quick Facts
About Quick Facts Tables
Esri Mobile Geodatabase Geometry Support
Format Type Identifier
Format
Reader/Writer
ESRI_MOBILE_GEODATABASE – Esri Mobile Geodatabase
Both
GEODATABASE_SDE – Esri Geodatabase (ArcSDE Geodb)
Both
GEODATABASE_FILE – Esri Geodatabase (File Geodb)
Both
GEODATABASE_SDE_RASTER_DATASET – Esri Geodatabase (ArcSDE Geodb Raster Dataset)
Both
GEODATABASE_FILE_RASTER_DATASET – Esri Geodatabase (File Geodb Raster Dataset)
Both
GEODATABASE_SDE_RASTER_CATALOG – Esri Geodatabase (ArcSDE Geodb Raster Catalog)
Reader
GEODATABASE_FILE_RASTER_CATALOG – Esri Geodatabase (File Geodb Raster Catalog)
Reader
GEODATABASE_SDE_MOSAIC_DATASET – Esri Geodatabase (ArcSDE Geodb Mosaic Dataset)
Writer
GEODATABASE_FILE_MOSAIC_DATASET – Esri Geodatabase (File Geodb Mosaic Dataset)
Writer
Operating System
Format Available On
Win 64-bit
Win 64-bit
Win 64-bit
Mac
Win 64-bit
Win 64-bit
Win 64-bit
Win 64-bit
Mac
Win 64-bit
Esri Geodatabase (Personal Geodb) Reader
Help topics specific to the 64-bit reader.
Win 64-bit
Dependencies
  • Esri ArcGIS Server 10.1 or newer (64-bit Geodatabase)
  • Esri ArcGIS Pro 2.7 or newer (Mobile Geodatabase)
Note  FME and ArcGIS must both be running on 64-bit machines.
Dataset Type
  • None (ArcSDE)
  • File (Mobile Geodatabase)
  • Folder (File-based)
Feature Type
Feature Class name
Typical File Extensions
  • Geodatabase: .gdb
  • Mobile Geodatabase: .geodatabase
Automated Translation Support
Yes
User-Defined Attributes
Yes
Coordinate System Support
Yes
Generic Color Support
No
Appearance Support (Surfaces Only)
Yes
Spatial Index
Always
Schema Required
Yes
Transaction Support
Yes
Geometry Type
geodb_type
Encoding Support
Yes
Geodatabase Raster Support
Band Interpretations Red8, Red16, Green8, Green16, Blue8, Blue16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64
Palette Key Interpretations UInt8, UInt16
Palette Value Interpretations RGB24
Nodata Value Yes
Cell Origin (x, y) 0.5, 0.5
Rotation Support No
GCP Support No
World File Support No
TAB File Support No
About FME and Geodatabase Rasters
Raster support is limited to File Geodatabases and Enterprise Geodatabases.
Esri Geodatabases can store rasters as raster datasets, raster catalogs, and raster mosaics.
FME Reading: FME supports reading raster datasets and raster catalogs. FME also supports reading mosaic datasets either as a single mosaicked raster through a raster dataset reader, or as multiple-source rasters through a raster catalog reader.
FME Writing: FME supports writing for raster datasets but not for raster catalogs or mosaic datasets.
