FME Form: 2024.1
Stopping a Translation
When you’re running a translation, the Stop tool becomes
available. Click the tool
to immediately stop the translation.
Note Sometimes stopping a translation causes FME to create
temporary files that can take up unnecessary disk space. It’s a good idea
to select Tools > Purge Temporary Files (or press Alt + C) after you
stop a translation.
What Happens After You Stop a Translation?
The log view will display Translation Stopped.
When you stop a translation, the output file is left incomplete and is not usable. If you run the file again, the entire translation will restart, overwriting any partial results from a previously aborted translation.
