FME Form: 2024.1
Running a Batch Translation
Open your existing workspace and select Batch Deploy from the Run menu. The Create Batch Translation Wizard launches. Click Next to proceed through the following dialogs:
Select Source Data
Click the file browser button to select the dataset(s) to use for the batch translation.
To add multiple files or folders, click the advanced browser button .
Add Files: Opens the file browser. You can select individual files, or Ctrl + click to select multiple files.
Add Folders: Opens the file browser so you can select entire folders to add to the reader. All files that are in the specified format in those folders will be included.
Remove: Removes the highlighted selection.
Subfolders: If there are subfolders below the initial dataset location, check the box to include them.
Identical Schema: Check this box if you know that all the files have the same schema. This is a time-saving function: there will be no difference in the workspace results. If you know the files have the same schema, FME will not have to perform an initial scan of all the files to determine their schema. Instead, FME will take the first file as being representative of the data model.
Set Destination Location For:
If you have specified more than one output destination, this pane appears for each destination.
Batch deploy this writer
Check this box, and enter or browse to the destination location.
Retain Source dataset basename in destination path
The output dataset name is always taken from the source name. However, this may not always make sense when using folder-based datasets. For example:
C:\myData\ShapeFiles\roads.shp
converted to MIF/MID and pointed to a MIFFiles folder would become
C:\myData\MIFFiles\ShapeFiles\roads.mif
This is because the "ShapeFiles" portion is treated by FME as the name of the source dataset, and is therefore included in the output.
To drop the source dataset name, uncheck this box. In the above example, the destination would now be:
C:\myData\MIFFiles\roads.mif
If checked, you have the option to Type the optional suffix to append to your destination dataset (for example, a file-type suffix).
Batch Translation Run Options
Select when you want to run the batch translation:
- Run Now: Execute the batch translation immediately, from within FME Workbench.
- Save scripts to run outside of FME Workbench: Type or browse for the location of the batch translation file. Note that batch files consist of both a .tcl file and a .bat file. Both files are needed to run the batch translation.
- Type the name of the .bat file; or
- Type fme tclfilename.tcl
To run the scripts outside of FME Workbench, go to the Windows DOS prompt and:
Run/Create the Batch Translation
Click the Finish button to run or create the batch translation.
See Also
