FME Form: 2024.1
Datums in FME
FME supports conversions between coordinate systems using different datums. Many datum transformations are not mathematically definable and require the use of grid of shifts. If you attempt to make a datum transformation of this kind without the appropriate grid shift file in place, FME will abort the translation.
The FME installation includes a configuration file for managing the use and location of grid shift files.
These files are found in the Reproject folder in the FME installation folder. For example, the file Nad27ToNad83.gdc includes file paths to both the Canadian and US grid shift files for the NAD27 <-> NAD83 transformations.
FME Reprojection Grid Add-on
The FME Reprojection Grid Add-on contains reprojection grid files that are not included in the FME Form installer.
Download the latest Grid Add-On
