WebSocketConnector
Connects to a WebSocket server to send or receive messages.
- Receive messages from WebSocket Servers
- Send messages to WebSocket Servers
- Connect to FME Flow WebSocket Servers
The first input feature will cause the WebSocketConnector to initialize a connection to the specified WebSocket Server URL.
When Request > Action is Send, the specified Data to Transmit value will be sent to the WebSocket server for every input feature, including the first feature that initiated the connection.
When Request > Action is Receive, a feature will be produced each time a message is received, with the contents of the message in the _output attribute. Each incoming feature will cause the WebSocketConnector to initialize a connection to the specified WebSocket server. The transformer will block while it waits to receive WebSocket messages until the remote host closes the connection.
When Receive Mode is Batch, each input feature will only block until the specified number of messages is received. If set to Stream, the transformer will continue running until the host closes the connection.
The output of this transformer will vary depending on the action performed.
- For the Receive action, received messages will be saved to the _output attribute value and output on a new feature
- A Send action will save the value of the sent message to an attribute
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
WebSocket Server URL |
Specify the URL of the remote WebSocket server. The default value is ws://localhost:7078. To initiate a secure connection to a WebSocket server using TLS, specify wss://<hostname>:<port> . |
Verify Certificates |
Yes or No (default Yes). If Yes, the WebSocketConnector verifies the certificate (or chain of certificates) of the WebSocket server before establishing a connection. |
Connection Preamble |
(Optional) Provide a value to be transmitted to the WebSocket server after establishing a connection and before transmitting or receiving any specified data. To connect to the FME Flow WebSocket server, use the following preamble: { To specify this preamble, click the ellipsis (...) to open the Connection Preamble dialog. Under FME Flow WebSocket Preambles, select the Open Public Stream template. Then, specify a ws_stream_ids value. ws_stream_ids identifies one or more message streams in order for the WebSocket server to associate them with the correct requesting application. |
Action |
Select the operation to perform. Choices are:
Message Encoding |
Select the encoding of the message. System Default (fme-system) is the default. When Action is Send, the Data to Transmit parameter is handled as an fme-system encoded string and transmitted as a utf-8 encoded string. If an encoding other than fme-system or utf-8 is selected, the value is encoded and sent as bytes. When Action is Receive, messages are received as bytes. The value of this parameter is used to decode the message to a string. If fme-binary is selected as an encoding for this parameter, the message will not be decoded and will remain intact as received. |
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Receive Options
Mode |
Two message receiving options are available:
Maximum Batch Size |
When Mode is Batch, specify the number of messages to receive before closing the connection. |
Send Messages Options
Data to Transmit |
Specify the data to transmit to the WebSocket server. This may be a text value, an attribute value, or the result of an expression. The value of this parameter will be treated as an fme-system encoded string. To send a message to the FME Flow WebSocket server, use this template: { To specify this template, click the ellipsis (...) to open the Data to Transmit dialog. Under FME Flow WebSocket Messages, select the Send Message template. Then, specify a ws_msg value. |
The following attributes can be selected for inclusion on the output features. Each output feature represents a message that was either sent or received.
_output |
The message sent or received, depending on the Action parameter:
_timestamp |
The time the message was created in unix time. |
Dialog Options - Tables
| Dependencies | |
Search for all results about the WebSocketConnector on the FME Community.
