TextPropertyExtractor
                                            Extracts the values of text attributes from input text geometry features.
        Text String  |
        Name the attribute to contain the value of the input text geometry feature's fme_text_string text attribute.  |
        Text Size  |
        Name the attribute to contain the value of the input text geometry feature's fme_text_size text attribute.  |
        Text Rotation  |
        Name the attribute to contain the value of the input text geometry feature's fme_rotation text attribute.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the TextPropertyExtractor on the FME Community.
