TextLocationExtractor
                                            Sets a text feature's geometry to be only the point location of the input.
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the TextLocationExtractor on the FME Community.
