RabbitMQConnector
                                            Connects to an AMQP 0-9-1 broker. Supports sending (producing) and receiving (consuming) messages.
- Producing messages to RabbitMQ
 - Aggregation of data from RabbitMQ topics and other message streams
 - Interoperability with Big Data analytics platforms
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Receive action, output features represent messages received from the broker.
 - After a Send action, output features represent messages sent to the broker.
 - After a Count action, output the number of messages in a queue.
 - After an Acknowledge action, set messages marked as acknowledged.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
        Credential Source  |
        Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
        Account  |
        Available when the credential source is Web Connection. To create a RabbitMQ connection, click the Account drop-down box and select Add Web Connection.... The connection can then be managed via Tools > FME Options > Web Connections.  |
        Host  |
        The endpoint of the RabbitMQ broker.  |
        Virtual Host  |
        The name of the virtual host used for multi-tenant brokers. Default is /.  |
        Broker Port  |
        The port to connect to the broker. Default is 5672.  |
        Web Port  |
        The port to connect to the RabbitMQ HTTP API. This is the same port for the admin web GUI. Default is 15672  |
        Enable SSL/TLS  |
        Whether to use a secure connection when connecting to the broker.  |
        Verify Certificates  |
        Whether to verify SSL/TLS certificates. Only choose No if there are expected certificate errors.  |
        User Name, Password  |
        The username and password to use when connecting to the broker.  |
        Action  |
        The type of operation to perform. Choices are:
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Acknowledge Options
        Receiving Connector Id  |
        The _connector_id attribute received from the Receive Action. Used for determining the message to acknowledge.  |
        Delivery Tag  |
        Attribute received from the Receive Action. Used for determining the message to acknowledge.  |
        Multiple Messages  |
        If Yes, acknowledge all messages prior to the current message.  |
Count Messages Options
        Queue  |
        The queue to count waiting messages.  |
Routing
        Exchange Type  |
        The exchange
        Exchange  |
        The exchange name consists of a non-empty sequence of these characters: letters, digits, hyphen, underscore, period, or colon.  |
        Routing Key  |
        The name used to route messages from exchanges to queues.  |
        Queue  |
        The queue name. If empty, the broker will create a unique queue name.  |
Receive Options
        Receive Mode  |
        Two message receiving options are available:
        Batch Size  |
        In Batch mode, specifies the number of messages to read per batch.  |
Advanced Properties
        Auto Acknowledge  |
        If Yes, the messages can be acknowledged in another transformer. The channel to the broker will stay open until the messages are acknowledged. Use the outputted _connector_id attribute in the acknowledgment transformer.  |
        Declare Exchange  |
        Whether to declare the exchange.  |
        Exchange Properties  |
        Properties to apply to the exchange
        Queue Properties  |
        Properties to apply to the queue
 For more information on RabbitMQ queues see: https://www.rabbitmq.com/queues.html  |
Routing
        Exchange Type  |
        The exchange
        Exchange  |
        Routing Key  |
Send Options
        Payload  |
        The content of the message. This is often JSON, but can be any string, binary, integer or floating-point value.  |
        Delivery Mode  |
Advanced Properties
        Declare Exchange  |
        Declare Queue  |
        Whether to declare the queue.  |
        Queue  |
        The queue to use.  |
        Queue Properties  |
 For more information on RabbitMQ queues, see: https://www.rabbitmq.com/queues.html  |
        Message Properties  |
        Additional message properties settable. The following keys are valid:
The following attributes can be selected for inclusion on the output features. Each output feature represents a message that was either sent or received.
        _delivery_tag  |
        Used to identify the message for acknowledgement.  |
        _payload  |
        The message payload. UTF-8 string if possible to decode, otherwise binary or numeric.  |
        _consumer_tag  |
        Used to identify the consumer.  |
        _exchange  |
        The exchange that the message was routed through.  |
        _headers  |
        A list of name/value pairs of headers on the message.  |
        _properties  |
        A list of name/value pairs of additional message properties.  |
        _redelivered  |
        True if a message is delivered but not fully acknowledged and re-queued.  |
        _routing_key  |
        The routing key used to route the message.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
| Dependencies | |
| History | Released FME 2019.0 |
Search for all results about the RabbitMQConnector on the FME Community.
