ParameterFetcher
                                            Adds an attribute to the feature, supplying it the value of a previously published parameter.
A parameter is a setting that you can pass values into when a translation is run. Parameters usually relate to a setting on a reader or transformer. The ParameterFetcher can be used to copy the value of one or more parameters to a corresponding number of attributes. The number of rows specified in the configuration dialog determine the number of exposed output attributes.
        Parameter Name  |
        When the ParameterFetcher is connected, the Parameter Name drop-down list shows the parameters that can be fetched from the workspace. The Parameter Name also exposes FME Parameters and FME Flow Parameters.  |
        Target Attribute  |
        The target attribute is the name of the attribute that will be created. When you select a parameter, this field is automatically filled with an appropriate name (for example, selecting a parameter named WIDTH will automatically name the target attribute _WIDTH). You can use the default name, or type a new name.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the ParameterFetcher on the FME Community.
