NetworkTopologyCalculator
Finds the connected lines that belong to the same network graph.
Network Topology in FME
In order to successfully generate a network topology, some conditions must be met.
Lines must touch (be snapped) at an end vertex - first or last.
Lines must be split at junctions. The TopologyBuilder can automate this process, but will not consider z-values (and so may not produce correct results for overpasses/underpasses, for example.)
A junction at an interior vertex (not an end vertex) produces a complex edge, which is not supported.
Network lines
Input Line features must be a topologically noded network with features connecting at line ends only. That is, all features must be split at junctions.
All connected lines are output through the Network port.
All non-linear features are output through the <Rejected> port.
Group By |
The default behavior is to use the entire set of features as the group. This option allows you to select attributes that define which groups to form. |
Complete Groups |
Dimension |
Select the type of coordinates to use when identifying topological connections:
Network ID |
Linear input features that are connected will be assigned the same network ID in the Network ID Attribute. |
Dialog Options - Tables
Transformer History
This transformer has been renamed from NetworkTopologyBuilder.
Keywords: Network, NetworkTopologyBuilder
Search for all results about the NetworkTopologyCalculator on the FME Community.
Keywords: network networktopologybuilder
