LengthToPointCalculator
                                            Calculates the length of a feature from its start until the closest spot to a point, and adds it as a new attribute. The point coordinates are taken from attributes in the original feature.
The length is calculated along the feature up until the spot on the feature that is closest to the given point.
To calculate the length of the entire feature, use the LengthCalculator.
To calculate the distance from the start of the line to each vertex, use the MeasureGenerator.
        Length Dimension  |
        By default, the 2-dimensional length of the line is calculated, and any Z values, if present, are ignored. To have a 3D length calculated, the length dimension parameter should be set to 3, and then the elevations will be included in the length computation.  |
        X Value Attribute  |
        The feature attribute from which to derive the x-value point coordinate.  |
        Y Value Attribute  |
        The feature attribute from which to derive the y-value point coordinate.  |
        Z Value Attribute  |
        The feature attribute from which to derive the z-value point coordinate.  |
        Length Attribute  |
        Name of the attribute to hold the length value that is calculated.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the LengthToPointCalculator on the FME Community.
