HoleCounter
                                            Adds a new attribute whose value is the number of holes in the feature. If the feature is not a polygonal feature, 0 will be returned.
Polygonal features enter through this port.
Features with the calculated number of holes leave through this port.
        Hole Count  |
        Name the attribute to contain the number of holes in the feature.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the HoleCounter on the FME Community.
