GoogleBigQueryConnector
                                            Accesses the Google BigQuery service to load or query tables from a Google Cloud account.
- Load CSV formatted data into new or existing BigQuery tables
 - Query BigQuery tables with the option to load the result to a specified destination BigQuery table
 - Create a queryable external table in Google BigQuery that links to existing data on Google Cloud Storage
Google BigQuery is a managed NoSQL database service.
The GoogleBigQueryConnector uses your Google Cloud account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer).
For more information about BigQuery, please visit the Google Cloud BigQuery product page.
The output of this transformer will vary depending on the Request > Action performed.
- After a Load Data action, output will include the following attributes:
        _project_id  |
        Name of the project_id loaded into.  |
        _table  |
        Name of the table loaded into.  |
        _dataset  |
        Name of the dataset loaded into.  |
        _rows_written  |
        Number of rows written to the specified table in the dataset.  |
- After a Query action, output will contain attributes set in the Exposed Attributes parameter, which correspond to the columns from the ran query. Geography functions will output as WKT (well-known text).
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
        Credential Source  |
        Credentials can be used from different sources. Using a web connection integrates best with FME but in some cases, you may wish to use one of the other sources.
        Account  |
        Available when the credential source is Web Connection. To create a Google BigQuery web connection, click the Account drop-down box and select Add Web Connection. The connection can then be managed via Tools > FME Options > Web Connections.  |
        Project ID  |
        The Google Cloud project id. Only required when the credential source is Web Connection.  |
        Action  |
        The type of operation to perform. Choices include:
Data Source
        Load Source  |
        Select the type of source data to be loaded:
        File to Load  |
        If Load Source is File, specify the location and name of the file to be loaded.  |
        Bucket  |
        If Load Source is Google Storage, specify the Google storage bucket.  |
        Path  |
        If Load Source is Google Storage, specify the Google storage path.  |
        File Type  |
        Only CSV is supported at this time.  |
        Header Rows to Skip  |
        For CSV files, specify the number of rows to skip at the top of the file. For example, if the file contains a single-line header, enter 1.  |
        Auto Detect Schema  |
        If Yes ,BigQuery will at best effort detect and set the data types of your data. If No, Defined Schema will be used.  |
        Defined Schema  |
        If Auto Detect Schema is No, define a schema using the following JSON format. [ For more information, see BigQuery's Specifying a schema documentation.  |
Load Options
        Table Handling  |
        If the specified Destination Table does not exist, it will be created. If it does already exist, the selected method will be used to load data:
 Table Handling is not an option when the Load Source is GCS External Table.  |
        Destination Dataset  |
        The dataset of the destination table.  |
        Destination Table  |
        The target table where results are loaded.  |
Query Options
        Query  |
        The SQL query to run. Note that when querying the BigQuery type NUMERIC, FME will receive the type fme_string.  |
Enable Destination Table
If enabled, query results will be stored in a table.
        Table Handling  |
        Destination Table  |
Exposed Attributes
        Exposed Attributes  |
        The list of attributes to output. Attributes should be the column names of the query.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
| Dependencies | Google Cloud Storage Account |
| History | Released FME 2019.1 |
Search for all results about the GoogleBigQueryConnector on the FME Community.
