GeometryPartExtractor
                                            Extracts selected geometry parts based on a Geometry XQuery.
Input Port
Features with geometries.
Features with newly extracted geometry parts.
Original feature with selected parts removed.
Features that were not modified by the transformer.
        Geometry XQuery  |
        Use this parameter if you want to isolate only a portion of the geometry passed in to the transformer. If no criteria are specified, the action will apply to the entire geometry at all levels. Selection can be based on structural location, geometry name, type, appearance information, traits, trait storage types, or definition reference. The syntax used is a restricted set of XQuery, where the return clause is fixed. The basic Geometry XQuery dialog allows you to construct simple selection queries by automatically writing the necessary query based on specified test clauses. Clicking the Switch to Advanced button opens the Advanced Editor, which allows you to type a query free-form, for more expressive queries. Note  Once you switch to Advanced mode, you will have to clear all parameters before you can return to Basic mode.
        A hierarchical geometry is represented as nodes of type geometry, with attributes containing information about traits, type, and name for each geometry. Note  Unlike other transformers that contain the Geometry XQuery parameter, this transformer requires that you specify a Geometry XQuery.  If
		you want to extract every single part, one method is to use an XQuery that matches the "Hierarchy Position" to "Leaf Node".  Alternatively, you can use a Deaggregator in hierarchy mode, which may produce more useful output.
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the GeometryPartExtractor on the FME Community.
Keywords: GeometryPartRemover
