FilenamePartExtractor
                                            Extracts specified parts of a filename path and returns the results as string attributes.
Example
For example, the path
C:\WINNT\Profiles\user\Desktop\roads.shp
would be extracted as follows:
                                                             Folder Path  |
                                                             C:\WINNT\Profiles\user\Desktop\  |
                                                             Full Filename  |
                                                             roads.shp  |
                                                             Filename Root  |
                                                             roads  |
                                                             Filename Extension  |
                                                             shp  |
                                                             Folder Name  |
                                                             Desktop  |
When parsing the path, both backslashes and forward slashes are handled as separators, regardless of operating system.
        Source Filename  |
        The attribute that holds the full filename and path.  |
        Folder Path  |
        If specified, this attribute will contain the full folder path of the Source Attribute, excluding the Full Filename.  |
        Full Filename  |
        If specified, this attribute will contain the full filename (including extension) of the Source Attribute.  |
        Root Filename  |
        If specified, this attribute will contain the root filename (without extension) of the Source Attribute.  |
        If specified, this attribute will contain the extension of the file specified in the Source Attribute.  |
        Folder Name  |
        If specified, this attribute will contain the folder name of the file specified in the Source Attribute.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the FilenamePartExtractor on the FME Community.
