AzureIoTConnector
                                            Connects to Azure’s IoT Hub through the MQTT protocol. Supports publishing device-to-cloud messages and receiving cloud-to-device messages as a device.
- Connect and control IoT devices
 - Manage device data for use on Azure IoT Hub and other services
 - Interoperability with Big Data analytics platforms
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Receive cloud-to-device messages action, output features represent messages received from Azure IoT Hub.
 - After a Send to Azure IoT Hub action, output features represent messages sent to Azure IoT Hub.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
        Credential Source  |
        Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
        Account  |
        Available when the credential source is Web Connection. To create an Azure IoT connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections.  |
        IoT Hub Name  |
        Available when the credential source is Embedded. The IoT Hub Name to use when connecting to Azure IoT Hub.  |
        Primary Key  |
        Available when the credential source is Embedded. The Primary Key to use when connecting to Azure IoT Hub. Any symmetric key for the IoT device can be used.  |
        SAS Token Expiry  |
        Available when the credential source is Embedded. The SAS Token Expiry time is used to set the amount of seconds the generated SAS token will last.  |
        CA Certificate  |
        The local file that contains the DigiCert Baltimore Root certificate. This file can be created from the Azure IoT SDK certs.c file located at https://github.com/Azure/azure-iot-sdk-c/blob/master/certs/certs.c. Include the lines from `-----BEGIN CERTIFICATE-----` to `-----END CERTIFICATE-----`, remove the `”` marks at the beginning and end of every line, and remove the `\r\n` characters at the end of every line.  |
        Device ID  |
        The device ID identifies the device to connect as through FME.  |
        Action  |
        The type of operation to perform. Choices are:
        QoS Level  |
        The MQTT protocol allows a Quality of Service (QoS) level to be set. The following levels are available:
 The QoS guarantees are achieved by performing differing levels of client-server handshake. As a result, higher QoS levels are expected to lower throughput.  |
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Receive Options
        Receive Mode  |
        Two message receiving options are available:
        Batch Size  |
        In Batch mode, specifies the number of messages to read per batch.  |
Send Options
        Payload  |
        The content of the message. This is often JSON, but can be any string, binary, integer or floating-point value.  |
The following attributes can be selected for inclusion on the output features. Each output feature represents a message that was either sent or received.
        _message_id  |
        The sequential identifier for the message.  |
        _payload  |
        The message payload. UTF-8 string if possible to decode, otherwise binary or numeric.  |
        _topic  |
        Available when the Action is Send to Azure IoT Hub. The topic the message sent to.  |
        _qos  |
        The quality of service level with which the message was sent or received.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
| Dependencies | |
| History | Released FME 2019.0 |
Search for all results about the AzureIoTConnector on the FME Community.
