AttributeCompressor
                                            Compresses and (optionally) encrypts the values of the specified attributes. The compressed and encrypted attribute values can be decompressed and decrypted using the AttributeDecompressor.
This transformer is particularly useful for compressing large blocks of XML, or geometry-storing attributes.
- Password-encrypt a value for storage in a database, for decryption with the AttributeDecompressor
 - Compress large blocks of XML to optimize storage
 - Compress large geometry for storage as blob fields to optimize storage
The AttributeCompressor lets you pick one, some, or all attributes to be compressed, and select the level of compression to apply. You can choose to encrypt the compressed attributes with a user-provided password, or leave them unencrypted.
Features passing through the transformer are output with their attribute names unchanged, but the selected values compressed. The AttributeDecompressor can be used to read them, either elsewhere within the workspace or in a different workspace.
In this portion of a workspace, an input dataset with complex boundary polygons is to be loaded to a non-spatial database.
The first step is to extract the geometry and convert it to an attribute with the GeometryExtractor. Having selected WKT as the encoding type, the geometry is stored in the new attribute _geometry.
The features are then passed to the AttributeCompressor to optimize them for storage prior to writing to the database.
The features are then sent to the database writer, where the compressed attributes will be written as blobs and stored.
In this portion of a workspace, a table of owners is written to a database.
Using the AttributeCompressor, the names and email addresses are password-encrypted for an added layer of personal information protection in the database.
In this example, the password is being created by a published user parameter that the user can assign as the workspace is run.
- The AttributeCompressor uses the zlib library to provide basic compression, and the OpenSSL library to provide encryption.
 - Different datasets have varying degrees of compressibility, and so results will vary.
 - When writing encrypted data to a database, it's best to use a Blob data type. That way the data is always stored in a binary data type and can be decrypted by the AttributeDecompressor. If the database field type is a string, then you should use the BinaryEncoder transformer before writing (to convert the binary value to a string) and the BinaryDecoder transformer after reading (to convert the string back to a binary value capable of being decrypted by the AttributeDecompressor).
Features with attributes.
All attributes, compressed and uncompressed.
        Attributes to Compress  |
        After connecting the transformer, click the browse button to select the attributes to be compressed and/or encrypted.  |
        Compression Level  |
        The value of this parameter controls the compression level which will be applied to the attributes. A value of 0 indicates that no compression should be used, while a value of 9 indicates that maximum compression should be used. The default value is 6.  |
        Encryption Type  |
        Use this parameter to select an encryption type. Currently, only the AES-256 encryption algorithm is supported.  |
        Password  |
        If encryption is being used, the value of this parameter will be used to generate an encryption key. The same value may then be used to decrypt the attribute values in the AttributeDecompressor transformer.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
Search for all results about the AttributeCompressor on the FME Community.
