AreaBuilder
                                            Takes a set of topologically connected linework and creates topologically correct polygon features where the linework forms closed shapes.
Example
The example below illustrates a set of topologically connected linework on the left and the output of the AreaBuilder transformer on the right. In the output, the topologically correct polygons are highlighted in blue where the linework formed closed shapes, while the lines that did not close are shown in red.
The input lines must be topologically correct and must neither self-intersect nor intersect each other. They must close at their endpoints. If these conditions are met, any area features implied by the input lines are created. (In addition to the Snapping Pre-Processing Parameters, you can also use the Snapper and Intersector to clean data that does not meet these conditions before it enters this transformer.) This transformer can also create polygons and donuts (holes/islands). Any lines that cannot be formed into polygons are joined together to create maximum length linestrings.
Contains the output polygons.
Contains any lines that did not close. If Create Donuts is checked, it also contains degenerate polygons.
        Group By  |
        The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form – each set of features that have the same value for all of these attributes will be processed as an independent group. No attributes other than the Group By ones will be carried across from the Input features to the output features.  |
        Complete Groups
 There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note  Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order.
        As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains.  |
        Consider Node Elevation  |
        Specifies whether curve endpoints must be connected in X,Y, and Z before being joined together (as opposed to just X, and Y). Note that if this is set to No, then the Connect in Z Mode parameter will specify how the Z values of segments that are not connected in 3D should be treated.  |
        Connect Z Mode  |
        If applicable, select a method for handling z values. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
        Preserve Lines as Path Segments  |
        If set to Yes, then when lines originating from different input curves are concatenated into a longer curve in the output, they will be left as separate segments in a path. The default is No, which means that such lines will be joined into longer lines in the output unless they have different properties (for example, traits, measures, geometry name).  |
        Build Internal Edges (Advanced)  |
        Specifies that coordinate "cycles" within a polygon are allowable and will be constructed; such polygons might be considered invalid by other parts of FME or by output formats. A "cycle" is a line segment that occurs twice in the same polygon's boundary (once in each direction).  |
        Check Curve Direction  |
        Specifies if the direction of the input curves needs to be considered while building polygons. If set to Yes, only curves that are tip-to-tail will result in polygons, all others will be output through the “Incomplete” port.  |
        Create Donuts  |
        If enabled, the resulting polygons will contain holes created by any other resulting polygons they completely contained. Following this, any holes that share a common edge will be dissolved together to make a larger hole. If unchecked, the resulting polygons are output via the Area port. Note that if you want to create donut polygons, you will need to use the DonutBuilder.
        Snapping Type  |
        When this parameter is set to None, no snapping takes place. When this parameter is set to End Point Snapping, the transformer: Snaps end points of lines together if their distances are within the specified tolerance. When this parameter is set to Vertex Snapping, the transformer does the following: Snaps vertices of lines together if their distances are within the specified tolerance. When two features are snapped together, the feature that entered the factory most recently is the one that is modified.  |
        Snapping Tolerance  |
        Snapping Tolerance specifies the distance, in ground units, that the snapping occurs between features.  |
        Accumulation Mode  |
        If Drop Incoming Attributes is chosen, the output feature will not preserve any input attributes. If Merge Incoming Attributes is chosen, the output feature will merge all input attributes. If Use Attributes From One Feature is chosen, the output feature will get attributes from only one input feature.  |
        Generate List  |
        When enabled, adds a list attribute to the output features, containing an element for each input feature which contributed to that geometry, in order of appearance. This parameter can also be used to preserve attributes from input features.
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the AreaBuilder on the FME Community.
