XSD-Driven XML Reader Parameters
Application Schema
XSD Selection
Specifies the location of the XSD Schema document.
xsi:schemaLocation
Specifies the location of the XSD Schema document via whitespace-separated namespace-URI and xsd-location-URL pairs, following the same syntax as the xsi:schemaLocation attribute.
For example, the following specifies two URI-URL pairs:
http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd urn:cgi:xmlns:CGI:GeoSciML:2.0 http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd
Features
Feature Paths
Identifies the top-level element, or any descendant of a top-level element, in the XSD Schemas that should be mapped into FME features.
A single top-level element can be identified via a qualified name, QName, which is a colon-separated optional prefix and a local name. The prefix or local-name part may also be set to an asterisk (*) wildcard. For example:
- a:feature
- feature
- *:feature
- a:*
Paths of QNames (forward-slash-separated (/) QNames) must be used to map non-top-level elements defined in the XSD Schema. The non-top-level element declarations must be reachable via a top-level element. Thus, the first QName in the path must be a top-level element. For example:
rdf:RDF/cim:ConnectivityNode
where the XSD Schema declares “RDF” as a top-level element, but “ConnectivityNode” is only declared locally within “RDF”.
Multiple feature paths are separated via whitespace.
XSD Types as Features
Specifies a white-space-separated list of complex type definition QNames. Element declarations in the XSD Schema whose type matches or extends any of the listed type definitions in this parameter will be mapped into an FME feature.
Attributes
Elements as XML Fragments
Specifies a white-space-separated list of single-element QNames and/or white-space-separated list of path of QNames that should be mapped into xml fragment attributes.
The last element in the path of QNames is the element that should be mapped into an xml fragment attribute; ancestor elements in the path act as conditionals for the element to map. For example, given the QName Path “a/b/c”, where <a> is being mapped as a feature, then only <c> elements with a <b> parent will be mapped into an xml fragment attribute.
XSD Types as XML Fragments
Specifies a white-space-separated list of complex type definition QNames. Element declarations in the XSD Schema whose type matches or extends any of the listed type definitions will be mapped into xml fragment attributes.
Elements as Attributes to Ignore
Specifies a white-space-separated list of single-element QNames and/or white-space-separated list of path of QNames that should be ignored as attributes.
The last element in the path of QNames is the element to ignore; ancestor elements in the path act as conditionals for the element to ignore. For example, given the QName Path “a/b/c”, where <a> is being mapped as a feature, then only <c> elements with a <b> parent will be ignored.
XSD Types as Attributes to Ignore
Specifies a white-space-separated list of complex type definition QNames. Element declarations in the XSD Schema whose type matches or extends any of the listed type definitions will be ignored.
Max Attributes Per Nested Attribute
Limits the number of FME nested attributes that an XML element and its children are mapped into. If the specified limit is reached, then the XML element is simply mapped into an XML fragment.
Settings
XML Namespace Declarations
The legal values for this parameter are white-space-separated XML namespace declarations as they would appear in an XML element.
This parameter allows different namespace declarations to be used, other than the ones extracted from the parsed XSD documents.
Add XML Namespace Prefix To
The FME feature type and/or attribute names may include the XML Namespace prefixes used in the XSD Schemas. The prefix will be separated from the names by an underscore.
By default, the prefixes are not added to the names.
- Feature Types – Includes the prefixes in the feature types. Setting this parameter to Feature Types is necessary if the XSD Schemas contains feature types with the same name in different namespaces.
- Feature Types and Attributes – Includes the prefixes in both the feature types and attributes.
Validate Dataset
Determines whether the reader should validate the specified dataset against the XSD Schema.
Use this parameter to expose Format Attributes in FME Workbench when you create a workspace:
- In a non-dynamic scenario, this parameter allows you to expose additional attributes on multiple feature types. Click the browse button to view the available format attributes (which are different for each format) for the reader.
