Esri Geodatabase (XML Workspace Document) Quick Facts
About Quick Facts Tables
Format Type Identifier
GEODATABASE_XML
Reader/Writer
Reader
Operating System Restrictions
Format is available only on:
  • Windows 64-bit
Dependencies
ArcGIS 9+
The bit version (64-bit) must be the same for FME and ArcGIS.
Dataset Type
File
Feature Type
Table/Feature Class name
Typical File Extensions
.xml or .ZIP or .Z
Automated Translation Support
Yes
User-Defined Attributes
Yes
Coordinate System Support
Yes
Generic Color Support
No
Spatial Index
Always
Schema Required
No
Transaction Support
Not applicable
Geometry Type
geodb_type
Encoding Support
Yes
Esri Geodatabase (XML Workspace Document) Geometry Support
Geometry
Supported?
aggregate
yes
circles
yes
circular arc
yes
donut polygon
yes
elliptical arc
yes
ellipses
yes
line
yes
none
yes
point
yes
polygon
yes
raster
yes
solid
no
surface
yes
text
yes
z values
yes
