Downloading from FME Flow
in the FME Workbench toolbar. The Download from FME Flow dialog opens:
Note To download from FME Flow, you must have an FME Flow
configured and available. For more information, contact your System Administrator.
Tip If you open the Translation Log, you can view connection and processing statistics while connected to FME Flow.
- FME Flow Connection: Specify the connection for the FME Flow from which you want to download. For more information, see Connecting to FME Flow.
- Repository Name: The name of the repository that contains the item to download. Workspaces, custom formats and custom transformers are stored in specific folders (called "repositories") on FME Flow. Select a repository from the pull-down list.
- Selected Item Name:The name of the workspace, custom transformer, or custom format to download (selected below).
- Repository Browser: The items that are currently stored in the repository. Select an item to download.
- Download data files, if present: If the workspace, custom transformer, or custom format has file resources that also need to be downloaded, check this box.
Click Download. You are prompted to save the files to a local folder.
