Upload Connections
                                                If your workspace contains any database or web connections, use the Upload Connections dialog to specify the connections you want to upload. Unless previously uploaded, you must upload any connections you want to reference when the workspace runs from FME Flow.
Check the box for each connection you want to upload.
Click Next. If the workspace contains any FME Packages, the Upload Packages dialog opens. Otherwise, the Register Services dialog opens.
