ReprojectLengthCalculator
Converts a given length from one coordinate system to another.
Jump to Configuration
- Determining text heights and widths
- Reprojecting distances stored as attribute values
The ReprojectLengthCalculator receives features with geometry and reprojects a given distance from one coordinate system to another.
The transformer starts with two points. One is the first coordinate of the input feature’s geometry, and the second is calculated from that point using the Original Line Angle and Original Line Length. Both of these points are reprojected from the Source Coordinate System to the Destination Coordinate System. A new length is calculated from the reprojected points and added to the output feature as an attribute value.
Original Line Length is in the Source Coordinate System’s ground units. The length may be provided as an attribute, expression, constant, parameter, or conditional value.
The Original Line Angle may be provided as an attribute value, constant value, expression, user parameter, or conditional value.
Both the Source and Destination Coordinate Systems must be specified explicitly.
Reprojections are generally performed using the FME (CS-Map) library, however, this transformer will honor the Workspace Parameter Reprojection Engine, and will use the Esri Reprojection Engine if it is selected there, with or without an Esri product being installed.
Z values are not supported.
This transformer assumes all coordinate systems are Cartesian.
Example: Calculating reprojected text heights in a CAD file
In this example, we have a CAD file containing traffic signal locations and labels. The original file is projected as UTM83-10, but we want to know what will happen to the label height if we reproject to BCPOLY-83.
Note that the label's autocad_text_size value is 2.
The features are routed into a ReprojectLengthCalculator.
Note that three format-specific attributes have been exposed - autocad_text_size, autocad_text_string, and autocad_rotation. This was done in the Autodesk AutoCAD DWG/DXF Reader parameters, Format Attributes, so that we can access their values.
In the parameters dialog, we set Original Line Length to the exposed autocad_text_size attribute, and Original Line Angle to 90 degrees (pointing north).
Both the Source and Destination Coordinate Systems are specified explicitly.
The Reprojected Length attribute is named _length (default).
The output feature has a new attribute - _length - containing the value of the reprojected line length.
Note that the Coordinate System has not changed and is still UTM83-10. The feature itself has not been reprojected, its geometry not altered. The reprojection to BCPOLY-83 has only been used to calculate the _length value.
- This transformer requires that features have geometry to provide an initial coordinate. Non-spatial features will not produce valid output. To create geometry for non-spatial data with coordinates as attributes, consider using a VertexCreator.
- To calculate the reprojected length of a feature with line geometry, consider using a Reprojector (or other reprojection transformer) and LengthCalculator.
Coordinate System Support and Reprojection
CoordinateSystemDescriptionConverter
Looks up coordinate system names and definitions between FME’s internal format and common third-party and open source representations, storing the results as an attribute.
CoordinateSystemExtractor
Retrieves the name of the feature's assigned FME coordinate system into an attribute.
CoordinateSystemRemover
Removes the coordinate system from features, without modifying geometry or coordinates.
CoordinateSystemSetter
Assigns a specified coordinate system to features, without modifying geometry or coordinates.
LocalCoordinateSystemSetter
Assigns a specified local coordinate system to features, without modifying geometry or coordinates.
AttributeReprojector
Reprojects x and y coordinates stored as attributes from one coordinate system to another.
FME (default) or Esri
CommonLocalReprojector
Reprojects one or more features to a local coordinate system centered on the bounding box containing all features.
ReprojectAngleCalculator
Converts a given angle from one coordinate system to another.
Reprojector
Reprojects feature x and y coordinates from one coordinate system to another.
CsmapAttributeReprojector
Reprojects x, y, and optionally z coordinates stored as attributes from one coordinate system to another using the CS-MAP library.
CS-Map
CsmapReprojector
Reprojects feature x, y, and optionally z coordinates from one coordinate system to another using the CS-Map library.
CS-Map
EsriReprojector
Reprojects feature coordinates from one coordinate system to another using the Esri reprojection library.
Esri
GridInQuestIIReprojector
Great Britain
Northern Ireland
Republic of Ireland
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII engine from Ordnance Survey, for use in Great Britain, Ireland, and Northern Ireland.
Grid InQuestII
GtransAttributeReprojector
Sweden
Reprojects coordinates stored as attributes from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).
Gtrans
GtransReprojector
Sweden
Reprojects feature coordinates from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).
Gtrans
PROJAttributeReprojector
Reprojects coordinates stored as attributes from one coordinate system to another using the PROJ library.
PROJ
PROJReprojector
Reprojects feature coordinates from one coordinate system to another using the PROJ library.
PROJ
ReframeReprojector
Switzerland
Reprojects feature coordinates from one coordinate system to another in Switzerland, using the Reframe library from the Federal Office of Topography (swisstopo).
REFRAME
Reprojected
Features with a reprojected length value added to an attribute.
General
Specify a distance, in the Source Coordinate System’s ground units.
Original Line Angle
Specify an angle, in the Source Coordinate System.
Angle is measured counterclockwise from horizontal in degrees.
Specify the coordinate system of the input features.
Specify the coordinate system the Original Line Lengthis to be reprojected to.
Note that the feature itself will not be reprojected, and this parameter is only used for calculation of the Reprojected Length Attribute.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
None |
Aliases |
History |
The is the place for demos, how-tos, articles, FAQs, and more. Get answers to your questions, learn from other users, and suggest, vote, and comment on new features.
Search for all results about the ReprojectLengthCalculator on the .
