LineCloser
Turns input linear features into areas by adding their start point as the end point.
Example
Connect Z Mode |
Select a method. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
Dialog Options - Tables
Search for all results about the LineCloser on the FME Community.
