LeftRightSpatialCalculator
Computes relative position of Candidate input features relative to Base input features.
The geometry of a Base feature is restricted to lines.
See the example below. The Base lines are considered to be oriented from the start point to the end point (digitization sense). A Candidate feature is:
- located to the LEFT of a Base feature if looking down the Base line in the direction of the orientation (from start to finish);
- located to the RIGHT if the Candidate is on the right of a Base feature;
- UNDEFINED if the Base and Candidate features intersect, or if the Base feature has a single point.
Before being sent out through the Output port, each Candidate feature will have a list of its relative positions to each of the Base features attached to it. Each element of the list has two pieces of information:
- a "base_id" which identifies the base
- the computed relative "position"
Base features are dropped after being used.
Any Base feature that is not a line is output through this port. All null and aggregate Candidate features are output through this port. The valid part will output through the Output port, and the invalid part will output through the <Rejected> port.
Group By |
If you choose Group By attributes, Candidates are only compared against Bases that have the same values in these attributes. |
Complete Groups |
Use Candidate Center of Mass |
If you choose Yes (default), the algorithm will use only the center of mass of passed in Candidates instead of the whole geometry. |
Use Base Closest Point |
If you choose Yes, the algorithm will compute only at the point on the Base line that is closest to the first or "center of mass" point. Note For some cases, the mathematics in the algorithm may produce a result opposite to what the human eyes will subjectively expect.
If you choose No, the algorithm will use a "gravity" or "weighted" based method such that all segments are used; segments from the base line that are closer to the candidate will contribute a higher weight than the segments that are farther away. The weights are added for each of the base's segments and will produce left or right depending on the group consensus. This will usually produce a subjectively more visually appealing result. Note There may be some edge cases that would return an incorrect result.
Base Type |
Define whether only a Single Base will be supplied, or whether Multiple Bases will be supplied. If you choose Bases First, all Base features will enter the transformer first, before any Candidate features. |
Base ID Attribute (Required) |
Choose the Base attribute whose value will be used to identify it in the list of relative positions attached to each output Candidate. |
Relative Position List |
Specify the name of the list attribute that will be added onto all output Candidate features, and that will contain the relative positions. |
Dialog Options - Tables
Search for all results about the LeftRightSpatialCalculator on the FME Community.
Keywords: relative position
